Best for your buck front brake upgrade....
Post by 1stgenWizard » Sat Jun 13, 2020 12:58 am
Well there are many opinons on what could be the best upgrade for for your front brakes on your 1st gen probe, I plan on just listing what is out there and available at the time of this post for your probe.
Mazda 6 Brakes, bolt on...
You can buy these parts from just about any auto part resource to do this easy mod.
03-05 Mazda 6 => 11.1" => Fits no problem with a 16" wheel
06-07 Mazda 6 => 11.8" => Fits no problem with a 16" wheel
06-07 Mazda Speed 6 => 12.6" => Must have a 17" wheel minimum
Parts you will need in order to complete the swap and have to match the year corresponding rotor you are going to use.
-Front Calipers
-Front Caliper brackets
-Front Rotors
-Brake pads.
Re: Best for your buck upgrade....
Post by 1stgenWizard » Sat Jun 13, 2020 1:03 am
REIDSPEED Big Brake Kit
This kit is using rotors from a 1995 Mitsubishi 3000 GT VR4 twin turbo, with the center hole bored out to 2-7/8″
Calipers (Millenia S dual piston front calipers)
Brake pads (for stock Millenia S front)
And custom made Caliper brackets.
More info go here http://reidspeedinc.com/?page_id=144
Post by 1stgenWizard » Sat Jun 13, 2020 1:11 am
Hye-Dra-Cyl L.L.C. Big Brake Kit
This kit has many options.
This kit features the following parts;
12.2" Rotors (0.81" thick with 32 straight cooling vanes standard)
4 Piston Racing Brake Calipers (major manufacturer)
Braided Stainless Steel Brake Lines
Brake Pads (for street or Solo II use)
Mounting Brackets and Hardware
Installation Instructions.
Additional Cost Upgrades Include:
Slotted 12.2" Rotors
Heavy Duty Brake Pads for Solo I or Track Use
1.25" Thick Rotors with 32 Curved Cooling Vanes
1.25" Thick Rotors with 48 Curved Cooling Vanes
Re: Best for your buck front brake upgrade....
Post by 1stgenWizard » Tue Jan 16, 2024 9:55 am
