Stock Boost Controller Specs & Plumbing
Posted: Sun Feb 09, 2020 4:48 pm
Turbo Hoses
The image below is a view from the intake side of the turbocharger. The solenoid's function involves three hoses:
Hose #1 connects the boost solenoid to the turbocharger assembly.
Hose #2 connects the boost solenoid to the waste-gate actuator.
Hose #3 connects the boost solenoid to the intake duct between the mass air flow sensor and the turbocharger.
boostsolenoid
boostsolenoid2
Boost Solenoid
The boost solenoid is located just below the turbo inlet on the intake side. In the image below, the three hose connections as described above are labeled.
