Best for your buck front brake upgrade....
3 posts • Page 1 of 1
Post by 1stgenWizard » Sat Jun 13, 2020 12:58 am
Well there are many opinions on what could be the best upgrade for for your front brakes on your 1st gen probe, I plan on just listing what is out there and available at the time of this post for your probe.
Mazda 6 Brakes, bolt on...
You can buy these parts from just about any auto part resource to do this easy mod.
03-05 Mazda 6 => 11.1" => Fits no problem with a 16" wheel
06-07 Mazda 6 => 11.8" => Fits no problem with a 16" wheel
06-07 Mazda Speed 6 => 12.6" => Must have a 17" wheel minimum
Parts you will need in order to complete the swap and have to match the year corresponding rotor you are going to use.
-Front Calipers
-Front Caliper brackets
-Front Rotors
-Brake pads.
Some fitment issues for 1st gens, 2.5 mm will have to be taken from the caliper bracket to move the bracket over some to clear the rotor or add washers for spacing.(Ground down or machined off)
Re: Best for your buck upgrade....
Post by 1stgenWizard » Sat Jun 13, 2020 1:03 am
REIDSPEED Big Brake Kit
This kit is using rotors from a 1995 Mitsubishi 3000 GT VR4 twin turbo, with the center hole bored out to 2-7/8″
Calipers (Millenia S dual piston front calipers)
Brake pads (for stock Millenia S front)
And custom made Caliper brackets.
More info go here http://reidspeedinc.com/?page_id=144
Post by 1stgenWizard » Sat Jun 13, 2020 1:11 am
Hye-Dra-Cyl L.L.C. Big Brake Kit
This kit has many options.
This kit features the following parts;
12.2" Rotors (0.81" thick with 32 straight cooling vanes standard)
4 Piston Racing Brake Calipers (major manufacturer)
Braided Stainless Steel Brake Lines
Brake Pads (for street or Solo II use)
Mounting Brackets and Hardware
Installation Instructions.
Additional Cost Upgrades Include:
Slotted 12.2" Rotors
Heavy Duty Brake Pads for Solo I or Track Use
1.25" Thick Rotors with 32 Curved Cooling Vanes
1.25" Thick Rotors with 48 Curved Cooling Vanes
Return to “Brakes & Suspension”
cron
