W/Rear Disc Brake
1. Normal parking brake adjustment is made at the hand lever between the seat. Remove the six attaching screws in the center console, then remove console.
2. Tighten parking brake adjusting nut on the left side of the parking brake lever. This shortens the equalizer cable. Tighten the adjusting nut until it takes seven to ten notches to fully set the parking brake.
