Thermostat Temperature Specifications - Revision
88ford13Article No. 88-12-12
THERMOSTAT - TWO-STAGE - OPENING TEMPERATURE SPECIFICATIONS AND VALVE OPENING DIMENSIONS - SHOP MANUAL REVISION
FORD: 1989 PROBE
ISSUE: The two-stage engine coolant thermostat opening temperature specifications and dimensions are not published in the 1989 Probe Shop Manual, Section 27-01-4.
FIGURE 5:
ACTION: If service is required, use the information in Figure 5 which provides the opening temperature specifications of the sub-valve and main valve and the valve opening dimensions.
WARRANTY STATUS: "INFORMATION ONLY"
