Engine: Technical Service Bulletins
- Customer Interest
- Engine - Rough idle/Miss/Oil Consumption
- Engine - Tappets Noisy
- Steering Wheel - Vibration Felt/Noise Heard
- Vehicle - Vibration When Idling
- Vehicle - No Start/Low State of Battery Charge
- Instrument Cluster Warning Lights - Dimly Lit
- Engine - Spark Knock On Acceleration When Cold
- Engine - Hard Start/Hesitation/Rough Idle
- Oil Pressure Gauge - Erratic or Becomes Inoperative
- Rocker Arm Cover Gasket - Oil Leaks
- Engine - Idle Speed Varies Under Electrical Load
- Engine - Rough Idle/Hesitation/Backfire/Stalling
- By Symptom
- Abnormal wear/deterioration
- Customer Interest
- Driveability
- Erratic Operation
- False instrument warning light/gauges
- Leaks
- Low, Dead battery
- Noise
- Poor performance
- Starting problems
- Vibration
- All Technical Service Bulletins
- Adhesives and Sealants - Availability and Usage
- Engine - Repair Tips to Avoid Potential Damage
- Engine Gasket Surface - Cleaning Procedures
- Analog Oil Pressure Gauge - Application Chart
- Motor Oil - Viscosity Grade Recommendation
- Engine - New Gasket Sealer
- Engine - Normal Oil Consumption
