C221 - C240
Connector C221: Below Joint Box Near LH Interior Kick Panel
Connector C222: At RH Interior Kick Panel
Connector C223: Rear On Joint Box Near LH Interior Kick Panel
Connector C224: At RH Interior Kick Panel
Connector C225: Rear On Joint Box Near LH Interior Kick Panel
Connector C226: At RH Interior Kick Panel
Connector C227: At Electronic Control Assembly Forward Of Center Console
Connector C228: At Electronic Control Assembly Forward Of Center Console
Connector C229: At Electronic Control Assembly Forward Of Center Console
Connector C230: At Fuel Pump Relay On Relay Box
Connector C231: At Clutch Switch Above Clutch Pedal
Connector C232: At Clutch Switch Above Clutch Pedal
Connector C233: At Electrical Load Unit Forward Of ECA
Connector C234: At Instrument Cluster
Connector C235: At Instrument Cluster
Connector C236: At Vehicle Maintenance Monitor Near Interior Lamps
Connector C237: At Interval Governor On Relay Box
Connector C238: At Rear Wiper Switch Right Of Cluster
Connector C239: At Rear Window Defroster Relay On Relay Box
Connector C240: At Rear Window Defroster Switch Left Of Connector Cluster
