C241 - C260
Connector C241: At Main Light Switch Left Of Cluster
Connector C242: At Multi-Function Switch Left Of Cluster
Connector C243: At Foglamp Relay On Relay Box
Connector C244: At Dimmer Relay Near Front RH Side Of Engine Compartment
Connector C245: At Headlamp Relay Near Front RH Side Of Engine Compartment
Connector C246: At Stop/Tail Lamp Checker On Relay Box
Connector C247: In Glove Compartment
Connector C248: In Glove Compartment
Connector C249: At Capacitor Near LH Interior Kick Panel
Connector C250: At Cigarette Lighter
Connector C251: At Panel Lamp Dimmer Switch Right Of Steering Column
Connector C252: At Hazard Flasher Switch On Top Of Steering Column
Connector C253: At Flasher Unit On Relay Box
Connector C254: Behind Horn/Cancel Switch
Connector C255: Behind Cigarette Lighter
Connector C256: At Stoplamp Switch On Top Of Brake Pedal
Connector C257: Behind Control Assembly At Center Of Instrument Panel
Connector C258: At Blower Motor Forward Of RH Side Of Instrument Panel
Connector C259: At A/C Relay No.1 On Top Of Evaporator Case
Connector C260: At A/C Relay No.2 On Top Of Evaporator Case
