Thermal Vacuum Valve: Description and Operation
Fig. 20 Temperature vacuum switch--TVS:
This switch, Fig. 20, has a bi-metal disc which locates itself in one of two positions, depending on its temperature. One position allows free air flow in the vacuum line; and the other blocks air flow by sealing itself against the O-ring. The switching temperature is below the range of normal engine operating temperature.
The TVS may be used to control the vacuum signal to the thermactor dump valve, to reduce emissions.
The normally open TVS may block the purge vacuum signal to provide satisfactory cold driveability and reduce cold engine emissions. It may be also used to hold off EGR operation during cold engine operation.
The normally closed TVS may allow cold spark advance to provide satisfactory cold engine driveability.
