Flow of Diagnosis
Flow Of Diagnosis:
1. Complete the VEHICLE REPAIR HISTORY and the DRIVEABILITY WORKSHEET, getting a detailed description of the complaint. Verify condition by road testing the vehicle.
NOTE: The Vehicle Repair History and the Driveability Worksheets are located under "INFO TYPE" TECHNICAL/MANAGEMENT SUPPORT.
Perform underhood inspection.
VISUALLY INSPECT THE FOLLOWING:
a. Vacuum hoses for proper routing, tight connections, splits, kinks and foreign obstacles (BB).
NOTE: Some vehicle manufacturers use an orifice-insert within a vacuum line as a delay device. Do NOT mistake as a BB and cut the vacuum line.
b. Vacuum fittings for improperly capped or plugged ports. Be sure to check the throttle body area, also.
c. Electrical and ignition wires for proper routing, cracking, hardness and tight connections at both the distributor and the spark plugs, kinks, and abrasions. Ground connections should be clean and tight.
d. Verify that all components are properly installed and have not been modified or damaged.
e. Check for air or vacuum leaks around the intake and exhaust manifolds, as well as the throttle body.
f. The catalytic converter(s), muffler, exhaust pipes, brackets, and hangers for modifications or damage.
2. Check TSB'S for manual updates, testing procedures, warranty and recall information.
3. Refer to TESTING PROCEDURES/SYSTEM TESTS/TC-1 SYSTEM INTEGRITY CHECK. If symptom still exists refer to Powertrain Management/Fuel Delivery and Air Induction/Turbocharger/Testing and Inspection/Procedures/Diagnosis by Symptom.
