Electronic Spark Control Module: Service and Repair
REMOVAL:
1. Disconnect the negative battery cable.
Knock Control Module:
2. Remove the attaching screws and nuts from the module housing at the module retaining bracket.
Knock Control Module Electrical Connector:
3. Disconnect the electrical connector from the module and remove the module.
INSTALLATION:
1. Connect the electrical connector to the module housing.
2. Position the module under the retaining bracket and install the attaching screws and nuts.
3. Connect the negative battery cable.
