A/T - Low OR No Line Pressure Rise/Worn Throttle Cam
TECHNICAL BULLETIN # 233TRANSMISSION: 4EAT/G4A-EL, G4A-HL
SUBJECT: Worn throttle cam
APPLICATION: Ford, Mazda
DATE: Jan 1994
4EAT/G4A-EL, G4A-HL
Low/No line rise Worn throttle cam
A low (or no) line rise condition can be caused by a worn throttle cam.
In some cases, the throttle plunger will also need replacing. Replacement parts can be purchased at your local Mazda dealer.
Note
Due to the availability of these parts, you may want to order them now so you have them when you need them.
