Weather Seal Retainer Modification and Inspection
WEATHER SEAL RETAINER MODIFICATION
1. Remove the weather seal form the roof retainer.
2. Remove the roof retainer from the car.
3. Starting at the front of the roof retainer, enlarge the first three (3) attaching screw holes from 5 mm to 7 mm.
4. Re-position the roof retainer. Use flat washers on the enlarged holes.
5. Before tightening the roof retainer attaching screws, pull the roof retainer outward and then secure the attaching screws.
6. Reinstall the weather seal to the roof retainer.
7. If windnoise or water leak concerns are still present, proceed to the door opening body weatherstrip inspection.
DOOR OPENING UPPER BODY WEATHERSTRIP INSPECTION
Check for proper air and water sealing of the door glass to the upper door opening body weatherstrip.
PART NUMBER PART NAME CLASS
E92Z-6102316-A Push Pin Button B
GJ21-50-H81 Fastener C
E92Z-6102207-A Water Drain C
F02Z-6121597-A Glass Run Blow Out Clip B
Molding (Left)
F02Z-6121596-A Glass Run Blow Out Clip B
Molding (Right)
E92Z-6120557-B Door Opening Weatherstrip B
(Left)
E92Z-6120556-B Door Opening Weatherstrip B
(Right)
D6AZ-19562-AA Ford Clear Silicone Sealer B
OTHER APPLICABLE ARTICLES: 90-22-2, 90-7-5, 90-8-12
SUPERSEDES: 89-18-1
WARRANTY STATUS: Eligible Under Basic
Warranty Coverage
910806A Reseal And Test Rightside 1.0 Hr.
Front Floor Pan
910806B Reseal And Test Rightside 2.0 Hr.
Front Floor Pan With
Fender Removal
910806C Reseal And Test Rightside 1.0 Hr.
Front Floor Pan
910806D Reseal And Test Rightside 2.0 Hr.
Fender Removal
910806E Reseal And Test Cargo 1.5 Hr.
Area
910806F Reseal And Test Sunroof 1.0 Hr.
And Rear Of Headliner
910806G Reseal And Test Tail Lamps 1.5 Hr.
910806H Reseal And Test Door 0.7 Hr.
Glass/Mirror
BASIC PART NO. CONDITION CODE
7002010 68
OASIS CODES: 110000, 701000
