Brake Rotor - Machining Equipment/Warranty Information
Article No.94-25-2
12/12/94
^ BRAKES - AVAILABILITY OF ON-VEHICLE CALIPER - MOUNTED BRAKE ROTOR MACHINING EQUIPMENT AND WARRANTY COVERAGE INFORMATION
^ BRAKE ROTOR MACHINING - AVAILABILITY OF ON-VEHICLE CALIPER - MOUNTED BRAKE ROTOR MACHINING EQUIPMENT AND WARRANTY COVERAGE INFORMATION
FORD:
1979-95 MUSTANG
1981-95 ESCORT
1984-94 TEMPO
1986-95 TAURUS
1988-93 FESTIVA
1989-95 PROBE, THUNDERBIRD
1991-95 CROWN VICTORIA
1994-95 ASPIRE
1995 CONTOUR
LINCOLN-MERCURY:
1979-86 CAPRI
1981-87 LYNX
1984-92 MARK VII
1984-94 TOPAZ
1986-95 SABLE
1988-89 TRACER
1988-95 CONTINENTAL
1989-95 COUGAR
1991-94 CAPRI
1991-95 GRAND MARQUIS, TOWN CAR, TRACER
1993-95 MARK VIII
1995 MYSTIQUE
MERKUR:
1985-88 XR4TI
1988-89 SCORPIO
LIGHT TRUCK:
1984-90 BRONCO II
1984-95 RANGER
1986-95 AEROSTAR
1990-95 BRONCO, E-150, E-250, F-150, F-250
1991-95 EXPLORER
1993-95 VILLAGER
1995 WINDSTAR
This TSB is being republished in its entirety to include the 1994 and 1995 model years.
ISSUE:
On-vehicle caliper-mounted brake rotor machining equipment from Rotunda is now approved for warranty and service use. Brake roughness, pulsation and steering wheel nibble will occur when rotors wear unevenly (thickness variation). This article specifically addresses brake roughness, pulsation and steering wheel nibble resulting from disc brake rotor thickness variation induced by rotor runout.
ACTION:
Use Rotunda On-Vehicle Brake Lathes 104-00129, 104-00130, 168-00004, or 168-00005 to service vehicles with brake roughness. This method is more effective because it allows machining of the rotor while it is still mounted on the vehicle. This improves the overall run-out of the assembly.
Rotunda on-vehicle caliper-mounted brake rotor machining equipment may correct runout if used according to the equipment manufacturer's instructions. Refer to Figures 1 and 2.
Machining the rotor with the use of a caliper-mounted brake lathe will be an eligible repair under warranty for the vehicles listed.
NOTE:
THERE MAY BE ADDITIONAL MANUFACTURERS OF SIMILAR EQUIPMENT. FORD DOES NOT ENDORSE, INDICATE ANY PREFERENCE FOR, OR ASSUME ANY RESPONSIBILITY FOR EQUIPMENT FROM THESE FIRMS, OR FOR ANY SUCH ITEMS WHICH MAY BE AVAILABLE FROM OTHER SOURCES.
NOTE:
DEALERS THAT HAVE APPROVED ON-VEHICLE BRAKE ROTOR MACHINING EQUIPMENT ARE REQUIRED TO RESURFACE BRAKE ROTORS UNDER THE BUMPER TO BUMPER COVERAGE PERIOD. IF A DEALER HAS THE ON-VEHICLE BRAKE ROTOR MACHINING EQUIPMENT, ROTOR REPLACEMENT WILL ONLY BE ALLOWED WHEN THE ROTOR IS BROKEN OR DOES NOT HAVE ENOUGH MATERIAL TO ALLOW TURNING. SUCH REPLACEMENTS MUST BE AUTHORIZED BY SERVICE MANAGEMENT.
NOTE:
EXCEPTIONS TO THE LAST STATEMENT ARE REAR ROTORS ON THE TOWN CAR, GRAND MARQUIS, CROWN VICTORIA, MUSTANG AND FRONT ROTORS ON F-350, F-47 AND F-53 HEAVY DUTY LIGHT TRUCKS. ON THESE VEHICLES, ROTORS CANNOT BE MACHINED. SERVICE MANAGEMENT AUTHORIZATION IS NOT REQUIRED FOR THESE EXCEPTIONS.
SUPERSEDES: 93-13-3
OASIS CODES: 301000, 302000, 703000
