Door and Window - Windnoise and Water Leaks
90FORD07
WINDNOISE AND WATER LEAKS - NEW WEATHERSTRIP FOR AROUND THE DOORS AND WINDOWS
Article No. 90-7-5
FORD: 1989 PROBE
This TSB article is being republished in its entirety to correct the service parts required to perform this repair.
ISSUE: Windnoise and water leaks around the door and window may be caused by poor sealing of the weatherstrip.
ACTION: Install a new design weatherstrip with a thicker trailing edge that improves sealing. Refer to the 1989 Probe Shop Manual, Page 44-1-12 for service details.
PART NUMBER PART NAME CLASS
E92Z-6120556-B Weatherstrip - RH B
E92Z-6120557-B Weatherstrip - LH B
SUPERSEDES: 90-3-3
900705AT Weatherstrip - Both Sides 0.4 Hr.
900705A Weatherstrip - One Side 0.3 Hr.
BASIC PART NO. CONDITION CODE
7020530 48
OASIS CODES: 1300, 7100, 7112
