Evaporator Case - Water Leaks Into Passenger Compartment
89Ford22
AIR CONDITIONING-CONDENSATE LEAKS FROM EVAPORATOR CASE INTO PASSENGER COMPARTMENT-VEHICLES BUILT BEFORE 3/01/89
Article No. 89-16-7
FORD: 1989 PROBE
ISSUE: Condensate from the A/C system may leak into the passenger compartment if the evaporator drain tube becomes plugged or stuck shut.
Figure 1:
ACTION: Cut 1 to 1-1/4 inches off the end of the drain tube in front of the dash panel as shown in Figure 1. Refer to the 1989 Probe Shop Manual, Section 36-75 for service details.
891607A Correct Plugged Or Stuck 0.3 Hr.
Shut Evaporator Case Drain Tube
BASIC PART NO. CONDITION CODE
19858 48
OASIS CODES: 2610
