Hood - Whistling Noise From Front Of Hood
88ford14
Article No. 88-13-2
WINDNOISE - "WHISTLE" AT FRONT OF HOOD - VEHICLES BUILT BEFORE 3/14/88
NOISE -"WHISTLE" - WINDNOISE AT FRONT OF HOOD - VEHICLES BUILT BEFORE 3/14/88
FORD: 1989 PROBE
ISSUE: A "whistling" noise on 1989 Probe GT vehicles that sounds like it is coming from the front of the windshield may be caused by the front fascia to hood seal (leading edge of hood) not sealing properly.
FIGURE 2:
ACTION: To correct this, install a foam spacer under the lower edge of the hood seal. Refer to the following service procedure for detailed installation instructions.
1. Remove the seal to front fascia six (6) attaching screws and remove seal.
2. Install a foam spacer that is 5 mm x 5 mm x 800 mm to front fascia seal lower edge, Figure 2.
3. Install the seal with foam spacer to front fascia with six (6) attaching screws.
PART NUMBER PART NAME CLASS
Foam Spacer
(5mmx5mmx800mm)
Obtain Locally
OPERATION: 881302A
TIME: 0.3 Hr.
DLR. CODING: Basic Part No. 16612
Condition Code: 26
