Radio Removal Tool - Manual Revision
89ford26
SHOP MANUAL-1989-SECTION 35-03-USE OF RADIO REMOVAL TOOL T87P-19061-A
Article No. 89-18A-7
FORD: 1989 PROBE
ISSUE: Section 35-03 (Radio, Cassette Player and Compact Disc), in the 1989 Probe Shop Manual, has been revised to clarify the use of the radio removal tool T87P-19061-A.
ACTION: Refer to the pages following this TSB article for the revised material.
OASIS CODES: 2800
35-03-21 Radio, Cassette Player, and Compact Disc 35-03-21
DIAGNOSIS AND TESTING (Continued)
REMOVAL AND INSTALLATION
Radio, Tape Player and Compact Disc Removal
35-03-22 Radio, Cassette Player, and Compact Disc 35-03-22
REMOVAL AND INSTALLATION (Continued)
NOTE: These removal and installation procedures apply to all Probe radio options.
1. Disconnect the battery negative cable.
2. Remove the ash receptacle.
3. Remove the selector trim panel (automatic transaxle), or gearshift and boot trim panel (manual transaxle).
4. Remove the cigar lighter assembly.
5. Disconnect the cigar lighter connector.
6. Disconnect the cigar lighter lamp by twisting the socket.
7. Remove the two screws which attach the radio to the instrument panel.
8. Insert two Removal Tools T87P-19061-A into face plate holes (NOTE: First time radio removal requires flashing in bezel holes to be broken, which will require extra force) until tension of clips is felt. Flex outward on both sides simultaneously and pull radio from instrument panel using tool as handles.
9. Disconnect the electrical connectors and antenna cable.
35-03-23 Radio, Cassette Player, and Compact Disc 35-03-23
Installation
1. Connect the electrical connectors and antenna cable.
2. Install the radio.
3. Install the two attaching screws.
4. Connect the cigar lighter lamp to the cigar lighter assembly.
5. Connect the cigar lighter connector to the cigar lighter assembly.
6. Install the cigar lighter assembly.
7. Install the selector trim panel (automatic transaxle), or gearshift and boot trim panel (manual transaxle).
8. Install the ash receptacle.
9. Connect the battery negative cable.
CLEANING
Cassette Tape Player
Over a period of time, the playback head, capstans, and pinch rollers gather an oxide residue as the tape passes these components while playing. This oxide accumulation can cause weak or wavering sound and damage to the cassette tape and/or player.
For best performance, it is recommended that the player be cleaned every 10 to 12 hours of playing time with a Ford cassette cleaning cartridge or equivalent.
CAUTION: The use of other cassette cleaning products is not recommended, as these could cause damage to the player or cassette tapes.
