Sunroof Weatherstrip - White Chalky Wax Appearance
90ford05
Article No. 90-5-3
^ GLASS - FLIP - UP SUN ROOF - EXTERIOR WEATHERSTRIP HAS A WHITE CHALKY WAX APPEARANCE
^ SUN ROOF - EXTERIOR WEATHERSTRIP HAS WHITE CHALKY WAX APPEARANCE
FORD: 1989-90 PROBE
ISSUE: The exterior weatherstrip surrounding the sun roof glass may have a white chalky wax appearance. This condition may be caused by the material the weatherstrip is made from.
ACTION: Install a new improved sun roof weatherstrip. Refer to the following procedure for service details.
1. Remove the sun roof from the vehicle. Refer to the 1989/90 Probe Shop Manual, Section 46-12 for service details.
Figure 1:
2. Place the glass on a protected bench. Be careful not to scratch the glass or damage the hinges or latch handle, Figure 1.
3. Remove the original weatherstrip from the glass.
Figure 2:
4. Obtain the new weatherstrip and determine the outside (curved) section and the inside (flat) section, Figure 2.
Figure 3:
5. Install the new weatherstrip with the center seam at the center of the latch handle, Figure 3.
Figure 4:
6. Use a rubber mallet to gently seat the weatherstrip to the glass. Start at the corners and work in sequence 1, 2, 3 and 4 as shown in Figure 4.
NOTE: AVOID HITTING THE HINGES WITH THE MALLET.
7. Re-install the sun roof into the vehicle. Refer to the 1989/90 Probe Shop Manual, Section 46-12 for service details.
PART NUMBER PART NAME CLASS
E92Z-61502C50-A Weatherstrip C
900503A Install Weatherstrip 0.4 Hr.
BASIC PART NO. CONDITION CODE
70502C50 81
OASIS CODES: 1052, 1300, 1500
