Attachment III-B - Technical Instructions - 1993-95 Probe
Fuel Pump/Sender Jumper Wire Modification InstructionsORDER PARTS AS REQUIRED
ENGINEERING PART NUMBER DESCRIPTION QUANTITY
F52Z-14408-AA Jumper Harness 1
95874-S Tie Strap 1
Affected Vehicles:
All 1993, 1994 and 1995 Probe built through April 14, 1995
1. Connect Rotunda Memory Saver 014-R1064 to retain memory in radio settings, engine learn strategies, etc.
2. Open hood and disconnect battery negative cable.
3. Open liftgate. Fold rear seat back forward.
4. Remove cargo net and package tray, if equipped.
5. Remove cargo net fasteners, if equipped, or the two (2) upper screws holding the luggage compartment rear cover.
6. Unscrew the two (2) lower luggage compartment rear cover fasteners.
7. Remove the two (2) push pins on either side of the luggage compartment rear cover, then remove cover from vehicle.
8. Remove five (5) pushpins from around left luggage compartment side cover.
9. Remove seat belt trim and remove concealed pushpin.
10. Remove two (2) screws from luggage compartment side cover.
11. Carefully pull side cover away from body to disengage clips, disconnect compartment lamp and remove cover from vehicle.
12. Disconnect fuel pump electrical connector. See Figure 1.
13. Install jumper harness, connecting it to the fuel pump and the free end to the vehicle harness. See Figure 2.
14. Secure jumper harness using supplied plastic tie strap. See Figure 3.
15. Install luggage compartment side cover by first connecting compartment lamp then snapping cover in place.
16. Install two (2) screws, six (6) pushpins and seat belt trim.
17. Position luggage compartment rear cover and secure using removed fasteners and pushpins.
18. Install package tray and cargo net, if equipped.
19. Connect battery negative cable, close hood then remove Memory Saver.
20. Start vehicle to verify proper fuel pump function.
