M/T - MTX Updated Input Shaft and Locknut Change
89ford36
Article No. 89-25-12
TRANSAXLE - MTX - INPUT SHAFT - 2.2L WITHOUT TURBOCHARGER BUILT AFTER 9/14/88
Figure 1:
FORD: 1989 PROBE
ISSUE: The diameter of the threaded portion of the input shaft for the MTX transaxle has been increased. Because of this, the synchronizer sleeve and locknut are also larger, Figure 1. These new parts are not interchangeable with earlier built transaxles.
ACTION: If it is necessary to service the input shaft, synchronizer sleeve or locknut in any MTX transmission, check the build date on the certification label located on the driver's side "B" pillar.
PART NUMBER PART NAME CLASS
E92Z-7017-C Input Shaft C
E92Z-7072-D Synchronizer Sleeve C
E92Z-7N170-C Lock Nut C
OASIS CODES: 5800
