Front & Rear Split System
Fig. 1 Schematic Diagram Of A Typical Hydraulic Front & Rear Split Brake System:
Fig. 2 Bendix Dual Master Cylinder:
When the brake pedal is depressed, both the primary (front brake) and the secondary (rear brake) master cylinder pistons are moved simultaneously to exert hydraulic fluid pressure on their respective independent hydraulic systems. The fluid displacement of the two master cylinders is proportioned to fulfill the requirements of each of the two independent hydraulic brake systems, Figs. 1 and 2.
If a failure of a rear (secondary) brake system should occur, initial brake pedal movement causes the unrestricted secondary piston to bottom in the master cylinder bore. Primary piston movement displaces hydraulic fluid in the primary section of the dual master cylinder to actuate the front brake system.
Should the front (primary) brake system fail, initial brake pedal movement causes the unrestricted primary piston to bottom out against the secondary piston. Continued downward movement of the brake pedal moves the secondary piston to displace hydraulic fluid in the rear brake system to actuate the rear brakes.
The increased pedal travel and the increased pedal effort required to compensate for the loss of the failed portion of the brake system provides a warning that a partial brake system failure has occurred. When the ignition switch is turned on, a brake warning light on the instrument panel provides a visual indication that one of the dual brake systems has become inoperative.
Should a failure of either the front or rear brake hydraulic system occur, the hydraulic fluid pressure differential resulting from pressure loss of the failed brake system forces the valve toward the low pressure area to light the brake warning lamp.
