Rear Crankshaft Main Bearing Seal: Service and Repair
1. Using suitable tool, punch hole in seal metal between seal lip and cylinder block.
2. Using jet plug remover tool No. T77L-95333-B or equivalent screw in threaded end, then using slide hammer remove seal.
3. Use care to avoid damaging oil seal surface.
4. Install oil seal.
