Hazard Warning Flasher: Locations
The main fuse panel is located on the lefthand side of the engine compartment, near the battery. The interior fuse panel is located just above the lefthand side kick panel.
The flasher relay box is mounted below the lefthand side of the instrument panel, on the bulkhead.
