Check Engine or MIL Lamp
This lamp will be illuminated when the ignition switch is placed in the On position. After engine is started the lamp should go off, unless a problem has been detected by the EEC-IV system. After diagnosis and repair, the Check Engine/MIL lamp will automatically reset when stored codes are cleared from the EEC-IV system memory. After diagnosis and repair, EEC-IV memory may be cleared of stored codes as follows:Fig. 1 Jumper Wire Connections For Resetting. Check Engine Lamp:
1. With ignition switch in the Off position, connect a jumper wire between Self Test and Self Test Input (STI) connectors, Fig. 1. On Ford Crown Victoria, Mercury Grand Marquis and Lincoln Town Car models, the Self Test and STI connectors are gray in color and are located on the front of lefthand fender apron, near the Electronic Engine Control (EEC) relay. On Ford Mustang models, the Self Test and STI connectors are gray in color and are located on the lefthand fender apron. On Ford Tempo, 1987-90 Escort and Mercury Lynx and Topaz, the Self Test connector is gray in color and the STI connector is black in color and they are both located on the righthand fender apron near the front of the strut tower. On Ford Taurus and Mercury Sable, the Self Test and STI connectors are gray in color and are located on the righthand fender apron near the front of the engine in the area of the AIR pump and alternator. On 1987-88 Ford Thunderbird and Mercury Cougar, the Self Test and STI connectors are gray in color and are located on the lefthand fender apron near the strut tower. On 1989-91 Ford Thunderbird and Mercury Cougar, the Self Test and STI connectors are gray in color and are located on the righthand fender apron near the strut tower. On 1987 Lincoln Mark VII & 1987-89 Continental, the Self Test and STI connectors are gray in color and are located on the righthand side of fender apron near the ignition coil. On 1988-91 Lincoln Continental, the Self Test and STI connectors are attached to the Electronic Control Assembly, which is located in the engine compartment at the center of the firewall below the TFI ignition module.
2. Position ignition switch in On position, then disconnect jumper wire from test connector terminals. Disconnect jumper as soon as check engine lamp starts flashing.
