Fuel Pressure: Testing and Inspection
STO Connector:
STATIC PRESSURE TEST
1. Check for adequate fuel supply.
2. Turn key OFF
3. Install fuel pressure gauge to test port on fuel rail.
4. Install test lead to fuel pump lead of STO test connector.
5. Turn Key ON Engine OFF (KOEO).
6. Ground test lead to run fuel pump.
7. Check to determine if fuel pressure is within acceptable limits.
a. If pressure is low but greater than 3 psi (indicates fuel pump is running but not enough pressure) check for:
^ Plugged fuel filter
^ Kinked fuel line
^ Low voltage to pump (should be within 0.5 volts of battery voltage at connector).
^ Disconnect the fuel return line and note if fuel is being returned during this low pressure condition. If fuel is being returned, replace the fuel pressure regulator. Reconnect the fuel return line.
b. If pressure is less than 3 psi (pump not running) check for:
^ Defective fuse link
^ Inertia switch open
^ Wiring at fuel pump/tank connector loose or open
^ Fuel pump ground connection at chassis loose or defective
^ Improper fuel pump relay operation
If fuel supply and return lines are OK, and electrical supply and ground are OK, and fuel pressure is still low, replace fuel pump.
DYNAMIC PRESSURE TEST
1. Disconnect and plug the vacuum line to the pressure regulator.
2. Start engine and run at idle. Check to determine if fuel pressure is within acceptable limits. Refer to SPECIFICATIONS.
a. If pressure is low check for:
^ Restricted fuel line
3. Reconnect the vacuum line to the regulator. If fuel supply and return lines are OK, and electrical supply and ground is OK, and fuel pressure is still low, replace fuel pump.
LEAKAGE TEST
1. Momentarily activate fuel pump by grounding test lead. Raise pressure to approximate operating pressure.
2. Remove ground from test lead and note pressure on gauge. Pressure should remain within 2 psi for 3 minutes after lead is ungrounded.
a. If pressure is not maintained check for leaking fuel
^ Lines
^ Connectors
^ Injectors
b. Disconnect fuel return line and plug engine side. Momentarily activate fuel pump by grounding test lead. Raise pressure to approximate operating pressure. If pressure holds replace regulator and retest. Reconnect the fuel return line. If pressure is not maintained replace fuel pump.
