Fuel Pressure Release: Service and Repair
WARNING: Do not smoke, carry lighted tobacco or open flame of any type when working on or near any fuel related component. Highly flammable mixtures are always present and may be ignited, resulting in possible personal injury.
CAUTION: Fuel supply lines will remain pressurized for long periods of time after engine shut down. This pressure must be relieved before servicing of the fuel system is begun. A valve is provided on the throttle body for this purpose. Remove the air cleaner and relieve system pressure by using Rotunda pressure gauge tool T80L-9974-A or equivalent and drain the system through the drain tube.
a. Before disconnecting any fuel line, release the fuel pressure from the fuel system to reduce the possibility of injury or fire.
1. Start the engine.
2. Disconnect the fuel pump relay.
3. After the engine stalls, turn OFF the ignition switch.
4. Reconnect the fuel pump relay.
5. Use a rag as protection from fuel spray when disconnecting the hoses. Plug the hoses after removal.
6. When inspecting the fuel system, use the Rotunda Fuel Pressure Testing Kit 014- 00447 or the Rotunda Fuel Injector Tester/Cleaner 113-00001 or equivalent as required.
