Dashboard / Instrument Panel: Description and Operation
With the Headlamp Switch in the PARK or ON position, current is applied through the TAIL fuse and Headlamp Switch to the Instrument Illumination Lamps. All Instrument Illumination Lamps are grounded through the Panel Lamp Dimmer Switch. The switch also controls the brightness of the Illumination Lamps.
