With Conventional Instrument Cluster
2. Remove steering wheel as outlined elsewhere in this section.
3. Remove cluster module.
4. Loosen two cover hinge screws.
5. Remove six upper cluster cover attaching screws, then the cover. Use caution not to tear rubber seal that joins upper and lower portions of cluster cover panels.
6. Remove lower cluster cover panel.
7. Remove four cluster mounting screws, then disconnect two electrical connectors from rear of cluster.
8. Disconnect speedometer cable, then remove cluster from vehicle.
9. Reverse procedure to install.
