Backup Lamp: Description and Operation
With the Ignition Switch in the RUN position, voltage is applied through the METER fuse of the Interior Fuse Panel to the Backup Lamp Switch. When the transaxle is placed in reverse, the Backup Lamp Switch closes and current is supplied to the Backup Lamps.
