Brake Light Switch: Description and Operation
Typical Brake Pedal Position Switch:
The Brake On-Off (BOO) switch detects braking action (deceleration). In response to the BOO signal, the ECA modifies idle speed, air/fuel ratio, torque converter clutch operation on A/T applications, and A/C compressor (if equipped).
Switch contacts are closed when the brakes are APPLIED.
