Air Flow Meter/Sensor: Service and Repair
REMOVAL1. Disconnect negative battery cable.
2. Disconnect electrical connector.
3. Remove air duct from air filter cover.
4. Remove filter cover attaching bolts.
5. Remove filter cover.
6. Remove meter attaching nuts from inside air cleaner cover.
7. Remove meter.
Vane Air Flow (VAF) Meter Removal:
1. Position on air filter cover and install attaching nuts.
2. Position air cleaner cover and install attaching bolts.
3. Install air duct and secure with clamp.
4. Connect electrical connector.
5. Connect negative battery cable.
