Cylinder Identification Sensor: Description and Operation
Cylinder Identification (CID) Sensor:
The Cylinder Identification (CID) sensor detects cylinder #1 TDC compression stroke. The ECA uses this signal to calculate injector and ignition timing.
LOCATION
Distributor housing.
The ECA receives an input signal when the reluctor mounted on the distributor shaft rotates past two fixed magnetic pickups. This allows reference to #1 TDC and #4 TDC position.
