Required Equipment
The following equipment is required to diagnose and repair the Electronic Engine Control (EEC) system:Super Star II Tester:
Super STAR II Tester (Rotunda 007-0041A, or equivalent)
Super Star II Test Adaptor:
4EAT Super Star II Test Adapter:
Super STAR II Adaptor (Rotunda 007-00036 and 007-00095)
Analog Volt/Ohm Meter:
Analog Voltmeter, 0-20 Volts DC (alternate to Super Star II)
Jumper Wire:
Jumper Wires
Vacuum Gauge:
Vacuum Gauge (Rotunda 059-00008, or equivalent)
Tachometer:
Tachometer (Rotunda 059-00010, or equivalent)
Vacuum Pump:
Vacuum Pump (Rotunda 021-00014, or equivalent)
Digital Volt-Ohmmeter (DVOM):
Digital Volt-Ohm Meter (DVOM) (Rotunda 014-00407, or equivalent)
