Stalls at Idle, Deceleration
Engine stalls at stops and on deceleration.
POSSIBLE CAUSE ACTION
EGR malfunction,
EGR valve plunger loose or sticking,
flange gasket leaking,
solenoid valve malfunction
1. Check EGR system.
If OK, proceed to step 2
2. Check EGR electronic controls.
Initial timing incorrect Check Ignition Timing.
Restricted exhaust Check Catalytic Converter.
Idle speed too low Check operation of any idle speed controlling device. Check and adjust idle speed.
Vacuum leak Check vacuum lines and routing.
Check intake manifold and vacuum components.
