Throttle Body: Description and Operation
Throttle Body Assembly (2.2L):
The throttle body assembly controls engine intake airflow by way of dual butterfly valves.
LOCATION
Mounted to intake manifold/plenum.
Throttle linkage regulating butterfly operation is connected to the accelerator pedal assembly via a cable.
CONSTRUCTION
Constructed as a unit of die cast aluminum with an air bypass around the primary throttle plate.
