Rear Retractor Assembly
REMOVAL1. Unbuckle both shoulder belts from the carriers.
2. Remove the floor console.
3. Remove the two retractor assembly mounting bolts.
4. Disconnect the electrical connector.
5. Remove the retractor assembly.
1. Connect the electrical connector.
2. Position the retractor assembly and install the two mounting bolts.
3. Install the floor console.
4. Buckle the shoulder belts to the carriers.
5. Check the passive restraint system for proper operation.
