Ride Control Solenoid Valve: Service and Repair
FRONT1. Place vehicle on a level surface.
2. Apply parking brake, then raise hood.
3. Remove rubber cap from strut mounting block, then disconnect PRC control module electrical connector, if equipped.
4. Remove PRC control unit.
5. Reverse procedure to install.
REAR
2. Remove upper trunk side moulding and lower trim panel.
3. Disconnect PRC electrical connector, if equipped.
