Removal
1. Detach the shoulder belt from the buckle carrier.2. Cycle the buckle carrier to the B-pillar (retracted position).
3. Install a memory saver, then disconnect the battery negative cable.
4. Remove the A to B-pillar trim panel. Refer to appropriate Service Manual.
5. Remove the quarter trim panel. Refer to appropriate Service Manual.
6. Disconnect the front limit electrical connector. See Figure 2.
7. Remove the three (3) rail upper mounting bolts. See Figure 3.
8. Remove the rail upper mounting screw. See Figure 4.
9. Remove the two (2) rail side mounting bolts. Refer to Figure 5.
10. Remove the two (2) cable retaining capscrews. See Figure 5.
11. Remove the three (3) motor mounting bolts. See Figure 6.
12. Disconnect the motor electrical connector.
13. Remove the rail and motor assembly from the vehicle. See Figure 7.
14. Place rail and motor assembly on bench with outboard side facing up. The red release button on the buckle carrier should be facing upward. Refer to Figure 8.
15. Remove roll pin. See Figure 8.
16. Using a small flat-bladed screwdriver, lift locking tab. See Figure 9.
17. Separate rail from locking tab.
NOTE:
Place cable assembly on clean workbench to prevent contamination of lubricating grease on cable.
18. Pull cable and buckle carrier from rail.
