| Standard Hours | Manufacturer Warranty Hours | Skill Level | Notes |
| Diagnose/Test |
| Oil Leak, Diagnosis | 1.0 | 0.7 | C | |
| Replace |
| Complete Assembly Without Transfer Of Parts |
| Auto Trans | 5.2 | 3.6 | B | Includes: Remove Engine & Transaxle As An Assembly. Does Not Include: Transfer Of Any Part Of Engine Or Replacement Of Optional Equipment. |
| Manual Trans | 6.6 | 4.5 | B | Includes: Remove Engine & Transaxle As An Assembly. Does Not Include: Transfer Of Any Part Of Engine Or Replacement Of Optional Equipment. |
| Note |
| With AC, Add | 0.5 | 0.3 | B | |
| Complete Assembly With Transfer Of Parts |
| Auto Trans | 7.2 | 0.0 | A | Includes: Remove Engine & Transaxle As An Assembly. Transfer Of All Fuel & Electrical Units, Does Not Include Transfer Of Optional Equipment. |
| Manual Trans | 8.3 | 0.0 | A | Includes: Remove Engine & Transaxle As An Assembly. Transfer Of All Fuel & Electrical Units, Does Not Include Transfer Of Optional Equipment. |
| Note |
| With AC, Add | 0.5 | 0.0 | A | |
| Long Block |
| Auto Trans | 10.2 | 6.6 | B | Includes: R&R Engine & Transfer All Necessary Components Not Supplied With Long Block. |
| Manual Trans | 11.6 | 7.5 | B | Includes: R&R Engine & Transfer All Necessary Components Not Supplied With Long Block. |
| Note |
| Short Block |
| Auto Trans | 12.2 | 6.9 | A | Includes: Remove Engine & Transaxle As An Assembly And Transfer All Necessary Components. |
| Manual Trans | 13.6 | 7.8 | A | Includes: Remove Engine & Transaxle As An Assembly And Transfer All Necessary Components. |
| Note |
| With AC, Add | 0.5 | 0.3 | A | |
| To Grind Valves, Add | 6.2 | 4.4 | A | |
| Overhaul/Rebuild |
| Auto Trans | 23.0 | 0.0 | A | Includes: Remove Engine & Transaxle As An Assembly. Disassemble & Clean Engine, Ridge Ream & Hone Cylinders, Inspect And Replace All Necessary Components, Grind Valves And Tune-Up. |
| Manual Trans | 24.2 | 0.0 | A | Includes: Remove Engine & Transaxle As An Assembly. Disassemble & Clean Engine, Ridge Ream & Hone Cylinders, Inspect And Replace All Necessary Components, Grind Valves And Tune-Up. |
| Note |
