Vacuum Brake Booster: Adjustments
1. Remove master cylinder from vehicle.
2. Position master cylinder gauge T87C-2500-A, or equivalent, on end of master cylinder.
3. Loosen setscrew and push gauge plunger against bottom of primary piston.
4. While holding gauge in position, tighten setscrew.
5. Invert gauge and place over brake booster pushrod. Reading should be zero.
6. If clearance is not zero, loosen pushrod locknut and adjust pushrod.
7. Reverse procedure to install.
