Engine Valve Spring Retainer/Upper Seat - Parts Change
Article No.
94-16-10
08/10/94
ENGINE - 2.0L - VALVE SPRING RETAINER KEY AND VALVE UPPER SPRING SEAT PART CHANGES
FORD:
1993-94 PROBE
ISSUE:
The valve spring retainer key's shape and outside diameter have been changed and requires a revised valve upper spring seat.
ACTION:
If service is required, change the valve spring retainer key and valve upper spring seat as a set. The revised and previous parts are not interchangeable. Refer to the 1993-94 Probe Service Manual, Section 03-01B and Figure 1, for service details.
PART NUMBER PART NAME Class
F32Z-6514-E Seat - Valve Spring (Upper) CG
F32Z-6518-A Valve Spring Retainer Key CG
OASIS CODES: 499000
