Engine: Technical Service Bulletins
- Customer Interest
- Hydraulic Lash Adjusters - Metallic Ticking Noise
- Engine - Noise/Misses/Stalls/Runs Rough/Low Power
- Engine - Lean Driveability Symptoms
- Instrument Cluster Warning Lights - Dimly Lit
- Ignition - Hard/No Start, Distributor Stator Replacement
- Oil Pressure Gauge - Reads Low
- Engine - Vibration/Resonance At Idle
- By Symptom
- Customer Interest
- Driveability
- False instrument warning light/gauges
- Noise
- Poor performance
- Starting problems
- Vibration
- Customer Interest
- All Technical Service Bulletins
- Engine - Repair Tips to Avoid Potential Damage
- Engine Gasket Surface - Cleaning Procedures
- Main and Crankpin Journal - Diameter Revision
- Water Pump/Pulley - Design Modification
- Instrument Cluster Gauges - Test Procedure Revised
- Motor Oil - Viscosity Grade Recommendation
- Engine Valve Spring Retainer/Upper Seat - Parts Change
- Engine - New Gasket Sealer
