Manual Transaxle
Catalyst & Exhaust System:
1. Remove exhaust inlet pipe-to-converter nuts. Discard nuts.
2. Remove gasket and discard.
3. Remove converter-to-muffler inlet pipe and resonator nuts. Discard nuts.
4. Remove gasket and discard.
5. Remove converter.
1. Inspect converter for deterioration and restriction. Replace if needed.
2. Place converter into mounting position.
3. Install new gasket between converter and muffler inlet pipe and resonator.
4. Install new converter-to-muffler inlet pipe and resonator nuts.
5. Install new gasket between converter and exhaust inlet pipe.
6. Install new muffler inlet pipe-to-converter nuts.
7. Start engine and inspect for exhaust leaks.
