A-Z Component List
Component Name: Location
A/C Clutch Field Coil: RH front of engine, part of A/C compressor assembly
A/C Clutch Thermal Protection Switch: RH front of engine, near A/C compressor assembly
A/C High Pressure Switch: RH front of engine compartment
A/C Relay: LH side of engine compartment, in engine compartment fuse box
A/C-Heater Control Assembly: Center of I/P
A/C-Heater Control Assembly Illumination: Behind center of I/P
ABS Control Module: Behind LH side of I/P, left of steering column
ABS Hydraulic Unit: LH rear of engine compartment
ABS Main Relay: LH side of engine compartment, on RH side of engine compartment fuse box
ABS Test Connector C229: Behind LH side of I/P, near ABS control module
Air Bag Diagnostic Monitor: Behind LH side of I/P, right of interior fuse panel
Alternator: RH rear of engine
Anti-theft Control Unit: Behind LH side of I/P, on central processing unit (CPU)
Ashtray Illumination: Under center console, in ashtray
Backup Lamp Switch: LH side of engine, on front of transaxle
Barometric Pressure (BARO) Sensor: Behind RH center of I/P
Blower Assembly (With A/C): Behind RH side of I/P
Blower Assembly (Without A/C): Behind RH side of I/P
Blower Motor: Behind RH side of I/P. in blower assembly
Blower Motor Resistor: Behind RH side of I/P, in blower assembly
Brake Fluid Level Switch: LH rear of engine compartment on brake fluid reservoir
Brake On/Off Switch: Behind LH side of I/P, top of brake pedal support
Canister Purge (CANP) Solenoid Valve: RH rear of engine compartment
Central Processing Unit (CPU): Behind LH side of I/P, on rear of interior fuse panel: C2000
Center Radiator Crash Sensor: Center front of vehicle, near engine compartment hood latch assembly
Cigar Lighter: Center of center console, near ashtray
Cigar Lighter Illumination: Under center console, near cigar lighter
Clockspring Assembly: Top of steering column, part of combination switch
Clutch Cycling Pressure Switch: RH rear of engine compartment, on A/C accumulator
Clutch Pedal Position (CPP) Switch: Behind LH side of I/P, top of clutch pedal support
Condenser Fan Motor: Center front of vehicle, in front of radiator
Combination Switch: Top of steering column C207,
Coolant Temperature Sender: Top LH side of engine
Cooling Fan Motor: Front of engine compartment, behind radiator
Crankshaft Position (CKP) Sensor: Lower LH side of engine
Data Link Connector (DLC) C135 (Automatic): LH side of engine compartment, on fender apron
Data Link Connector (DLC) C135 (Manual): LH side of engine compartment, on fender apron
Data Link Connector (DLC) C191: LH side of engine compartment, on fender apron
Daytime Running Lamps (DRL) Control Module: Behind LH side of I/P, left of steering column
Distributor: Top LH front of engine
Dome/Map Lamp Assembly: Center of windshield header
DRL Relay: LH side of engine compartment, in engine compartment fuse box
EGR Solenoid Valve: RH rear of engine compartment
EGR Temperature Sensor: RH rear of engine compartment
EGR Valve Position Sensor: Center rear of engine
Engine Compartment Fuse Box: LH side of engine compartment, above wheel well
Engine Compartment Lamp: Underside of engine compartment hood
Engine Coolant Temperature (ECT) Sensor: Top LH side of engine
Engine Coolant Temperature Sensor (Cooling Fan): Top LH side of engine
Flasher Module: Behind LH side of I/P left of steering column
FPRC Solenoid Valve: RH rear of engine compartment
Fog Lamp Relay: LH side of engine compartment, in engine compartment fuse box
Fog Lamp Switch: Center of I/P
Fog Lamps: Lower front of vehicle on respective sides
Front Combination Lamps: Front of vehicle on respective sides
Fuel Injectors: Top of respective cylinders
Fuel Pump Relay: LH side of engine compartment in engine compartment fuse box
Fuel Pump/Fuel Gauge Sender: Below rear of car, inside fuel tank
Glove Box Lamp: Behind RH side of I/P
Glove Box Lamp Switch: Behind RH side of I/P
Graphic Equalizer: Lower center of I/P
Headlamp Relay: LH side of engine compartment, in engine compartment fuse box
Headlamp Retractor Control Module: Behind LH side of I/P, left of steering column
Headlamp Retractor Switch: Center of I/P
Headlamp Retractor Test Connector: LH side of engine compartment, in engine compartment fuse box
Headlamps: Front of vehicle, on respective sides
Heated Oxygen Sensor (HO2S): Lower center front of engine, in exhaust manifold
Hi Mount Stop Lamp: Top center front of liftgate, at top of rear window
High Speed Blower Motor Relay: Behind RH side of I/P, in blower assembly
High Speed Condenser Fan Relay: LH side of engine compartment, on RH side of engine compartment fuse box
High Speed Cooling Fan Relay: LH front of vehicle, on front of upper radiator support
Hood Switch: Center front of vehicle, on engine compartment hood latch assembly
Horn Relay: LH side of engine compartment, in engine compartment fuse box
Horn Switches: In center of steering wheel
Idle Air Control (IAC) Solenoid Valve: Center rear of engine compartment
Idle Switch: Center rear of engine compartment
Ignition Coil: LH front of engine compartment
Ignition Control Module (ICM): LH rear of engine compartment
Ignition Key Cylinder Lamp: Top of steering column, near ignition switch
Ignition Key Reminder Switch (Ignition): Top of steering column, part of ignition switch
Ignition Key Reminder Switch (Shift Lock Override): Center of center console
Ignition Switch: Top of steering column
Inertia Fuel Shutoff Switch: Lower RH side of luggage compartment, behind wheel well
Instrument Cluster: Top LH side of I/P
Instrument Panel Dimming Module: LH side of I/P, left of steering column
Intake Air Temperature (AT) Sensor: Top LH side of engine compartment, on LH side of air cleaner assembly
Interior Fuse Panel: Behind LH side of I/P, near kick panel
Joint Connector C103: LH front of vehicle. near left fog lamp, on G103
Joint Connector C106: LH side of engine, on G106
Joint Connector C168: LH side of engine compartment, in engine compartment fuse box
Joint Connector C169: LH side of engine compartment, in engine compartment fuse box
Joint Connector C202: Behind top LH side of I/P, on G202
Joint Connector C203: Behind LH side of 1/P, on G203
Joint Connector C234: Behind LH side of I/P, taped to I/P harness
Joint Connector C245: Behind LH side of I/P, taped to front harness
Joint Connector C250: Below lower RH front of center console, near powertrain control module (PCM)
Joint Connector C262: Behind top LH side of I/P, taped to air bag harness
Joint Connector C269: Behind LH side of I/P, taped to I/P harness
Joint Connector C270: Behind LH side of I/P, taped to I/P harness
Joint Connector C300: Below LH front seat, on G300
Joint Connector C400: Lower center rear of luggage compartment, on G400
Keyless Entry Module: In front of RH quarter panel, behind quarter trim
Knock Sensor (KS): Rear of engine
Left Crash Sensor: LH front of vehicle, behind front bumper
Left Door Courtesy Lamp Switch: On LH "B" pillar, in rear of LH door jamb
Left Door Key Cylinder Lamp: In top rear of LH door, part of key cylinder
Left Door Key Cylinder Switch: In top rear of LH door, part of key cylinder
Left Door Lock Motor (With Anti-theft): In rear of LH door
Left Door Lock Motor (Without Anti-theft): In rear of LH door
Left Door Lock Switch: In top rear of LH door, part of key cylinder
Left Door Panel Lock Switch: On armrest of LH door
Left Footwell Courtesy Lamp: Under LH side of I/P
Left Front ABS Wheel Speed Sensor: On LH front wheel assembly
Left Front Door Speaker: In lower front of LH door
Left Headlamp Retractor: LH front of engine compartment
Left Heated Oxygen Sensor (HO2S): Lower center front of engine, in exhaust manifold
Left Horn: Inside front of LH front fender
Left Outside Door Handle Switch: In top rear of LH door, near handle assembly
Left Power Window Motor: In lower rear of LH door
Left Power/Heated Mirror: Top front of LH door
Left Rear ABS Wheel Speed Sensor: On LH rear wheel assembly
Left Rear Speaker: In front of LH quarter panel, behind quarter trim
Left Vanity Mirror Lamp: LH side of windshield header
License Plate Lamps: Center rear of liftgate, on respective sides of license plate
Liftgate Key Switch: In RH rear of luggage compartment
Liftgate Washer Motor: Lower RH rear of luggage compartment, on liftgate washer fluid reservoir
Liftgate Washer Switch: Center of I/P
Liftgate Wiper Motor: Inside LH rear of liftgate
Liftgate Wiper Switch: Center of I/P
Low Speed Blower Motor Relay: RH front of vehicle, on front of upper radiator support
Low Speed Condenser Fan Relay: LH side of engine compartment, on RH side of engine compartment fuse box
Low Speed Cooling Fan Relay: LH front of vehicle, on front of upper radiator support
Luggage Compartment Lamp: LH side of luggage compartment C422,
Luggage Compartment Lamp Switch: Center rear of luggage compartment, near hinge support
Main Window Control Switch: On armrest of LH door
Manual Lever Position Switch (Automatic): Lower front of transaxle
Mass Air Flow (MAF) Sensor: Top LH rear of engine compartment, on rear of air cleaner assembly
Moonroof Motor Assembly: Center of roof, behind moonroof
Moonroof Relay: Center of roof, behind moonroof
Moonroof Switch: Center of windshield header
Oil Pressure Sender: Lower RH rear of engine, near starter assembly
Overdrive Off Switch: Front of center console
Park Brake Switch: Below rear of center console, on par brake assembly
Park Lamp Relay: LH side of engine compartment, in engine compartment fuse box
Park Range Switch: Below center console, on front of gear selector assembly
Park/Neutral Position Switch (Manual): LH side of engine, on top of transaxle
PCM Power Relay: LH side of engine compartment, in engine compartment fuse box
Power Door Lock Relay: Top of RH kick panel
Power Lumbar/Bolster Compressor Motor: Under center rear of LH front seat
Power Lumbar/Bolster Switch: LH side of LH front seat
Power Mirror Switch: On armrest of LH door
Power Seat Lift Motor: Under center front of LH front seat
Power Seat Slide Motor: Under center front of LH front seat
Power Seat Switch: LH side of LH front seat
Power Seat Tilt Motor: Under center of LH front seat
Power Steering Pressure Switch: RH front of engine compartment, on power steering line
Powertrain Control Module (PCM) (Automatic): Below center front of center console
Powertrain Control Module (PCM) (Manual): Below center front of center console
Program Connector C424: In RH rear of luggage compartment
Pulse Signal Generator: LH side of engine. on top of transaxle
Radio (AM/FM Stereo): Center of I/P
Radio (Premium Sound With Graphic Equalizer): Center of I/P
Radio (Premium Sound): Center of I/P
Radio Amplifier: In front of RH quarter panel behind quarter trim
Radio Noise Capacitor: LH front of engine compartment, near ignition coil
Radio/CD Player (Premium Sound With CD Player and Subwoofer): Center of I/P
Radio/CD Player (Premium Sound With CD Player, Graphic Equalizer, and Subwoofer): Center of I/P
Rear Combination Lamps: Rear of vehicle, on respective sides
Rear Window Defrost Grid: On rear window
Rear Window Defrost Relay: RH front of vehicle, on front of upper radiator support
Rear Window Defrost Switch: Center of I/P
Right Crash Sensor: RH front of vehicle, behind front bumper
Right Door Courtesy Lamp Switch: On RH "B" pillar, in rear of RH door jamb
Right Door Key Cylinder Lamp: In top rear of RH door, part of key cylinder
Right Door Key Cylinder Switch: In top rear of RH door, part of key cylinder
Right Door Lock Motor (With Anti-theft): In rear of RH door
Right Door Lock Motor (Without Anti-theft): In rear of RH door
Right Door Lock Switch: In top rear of RH door, part of key cylinder
Right Door Panel Lock Switch: On armrest of RH door
Right Footwell Courtesy Lamp: Under RH side of I/P
Right Front ABS Wheel Speed Sensor: On RH front wheel assembly
Right Front Door Speaker: In lower front of RH door
Right Headlamp Retractor: RH front of engine compartment
Right Heated Oxygen Sensor (HO2S): Lower center rear of engine, in exhaust manifold
Right Horn: Inside front of LH front fender
Right Outside Door Handle Switch: In top rear of RH door, near handle assembly
Right Power Window Motor: In lower rear of RH door
Right Power/Heated Mirror: Top front of RH door
Right Rear ABS Wheel Speed Sensor: On RH rear wheel assembly
Right Rear Speaker: In front of RH rear quarter panel, behind quarter trim
Right Vanity Mirror Lamp: RH side of windshield header
Right Window Switch: On armrest of RH door
Safing Sensor: Behind center of I/P
Seat Belt Buckle Switch: In driver's seat belt buckle assembly
Self Test Input (STI) Connector C190: LH side of engine compartment, on fender apron
Shift Lock Actuator: Below front of center console, near rear of gear selector assembly
Speed Control Module: Behind LH side of I/P, left of steering column
Speed Control Servo: LH rear of engine compartment
Speed Control Switch Assembly: On steering wheel
SPOUT Test Connector 0177: LH side of engine compartment, near data link connectors (DLC)
Starter Clutch Pedal Position (SCPP) Switch: Behind LH side of I/P, top of clutch pedal support
Starter Interrupt Relay: LH side of engine compartment, in engine compartment fuse box
Starter Motor: Lower rear of engine
Steering Column Air Bag: Center of steering wheel
Subwoofer Amplifier: In front of LH quarter panel, behind quarter trim
Subwoofer Assembly: RH rear of luggage compartment
Throttle Position (TP) Sensor: Top LH rear of engine, on throttle body
Transaxle Control Module (TCM): Below center of I/P, forward of powertrain control module (PCM)
Transaxle Control Solenoid Valve: LH side of engine, on top of transaxle
Vehicle Speed Sensor (VSS): Lower rear of transaxle
Volume Air Flow (MAF) Sensor: Top LH side of engine compartment, on air cleaner assembly
VRIS Solenoid Valve #1: Center rear of engine compartment
VRIS Solenoid Valve #2: Center rear of engine compartment
Washer Fluid Level Sensor: RH front of engine compartment, in windshield washer fluid reservoir
Windshield Washer Motor: RH front of engine compartment, in windshield washer fluid reservoir
Windshield Wiper Motor: Top LH side of safety wall
