Part 1 of 3
Component Locations:
A/C CLUTCH FIELD COIL
A/C THERMAL PROTECTION SWITCH
CANISTER PURGE (CANP) SOLENOID VALVE
DATA LINK CONNECTOR (DLC)
DATA LINK CONNECTOR (DLC) (MANUAL ONLY)
EGR SOLENOID VALVE
EGR TEMPERATURE SENSOR
ENGINE COOLANT TEMPERATURE (ECT) SENSOR
ENGINE COOLANT TEMPERATURE SENSOR (COOLING FAN)
FPRC SOLENOID VALVE
FUEL INJECTOR #1
FUEL INJECTOR #2
FUEL INJECTOR #3
FUEL INJECTOR #4
IDLE AIR CONTROL (IAC) SOLENOID VALVE
INTAKE AIR TEMPERATURE (IAT) SENSOR
JOINT CONNECTOR
LOW SPEED BLOWER MOTOR RELAY
MASS AIR FLOW (MAF) SENSOR
HEATED OXYGEN SENSOR
PARK/NEUTRAL POSITION SWITCH (MANUAL)
POWER STEERING PRESSURE SWITCH
PULSE SIGNAL GENERATOR (AUTOMATIC) NC CLUTCH FIELD COIL
REAR WINDOW DEFROST RELAY
SELF TEST INPUT (STI) CONNECTOR
