S201 - S250
Splice Number -- Location
S201 I/P harness, behind center of I/P, near RH edge of harness channel
S202 Front harness, near Take Out (T/O) to ignition switch
S203 Front harness, near Take Out (T/O) to G201
S206 I/P harness, in Take Out (T/O) to instrument cluster connector C240
S207 I/P harness, near Take Out (T/O) to C206
S208 I/P harness, behind center of I/P, near RH edge of harness channel
S209 I/P harness, near Take Out (T/O) to C255 and C249
S211 (Automatic) Front harness, near Take Out (T/O) to C106
S211 (Manual) Emission harness, near safety wall grommet
S212 Emission harness, near Take Out (T/O) to powertrain control module (PCM)
S215 I/P harness, near Take Out (T/O) to C206
S216 I/P harness, in Take Out (T/O) to instrument cluster connector C240
S217 I/P harness, near Take Out (T/O) to instrument cluster connector C240
S218 I/P harness, near Take Out (T/O) to C255 and C249
S221 Rear harness, near Take Out (T/O) to C204
S222 Rear harness, near Take Out (T/O) to C204
S223 Emission harness, neat Take Out (T/O) to powertrain control module (PCM)
S225 Front harness, near safety wall grommet
S226 Front harness, near safety wall grommet
S228 I/P harness, near Take Out (T/O) to joint connector C270
S229 Front harness, near Take Out (T/O) to C251
S230 Rear harness, behind LH side of I/P
S231 Front harness, near Take Out (T/O) to interior fuse panel connector C214
S232 I/P harness, near Take Out (T/O) to joint connector C270
S236 Front harness, near Take Out (T/O) to ignition switch
S237 Front harness, near Take Out (T/O) to ignition switch
S238 Rear harness, near Take Out (T/O) to C204
S239 Emission harness, near Take Out (T/O) to powertrain control module (PCM)
S240 Emission harness, in Take Out (T/O) to transaxle control module (TCM) connector C258
S241 I/P harness, near Take Out (T/O) to G200
S242 I/P harness, near Take Out (T/O) to joint connector C270
S244 I/P harness, near Take Out (T/O) to joint connector C269
S245 Emission harness, in Take Out (T/O) to C255
S246 Rear harness
S247 Rear harness
S248 Rear harness
S249 Rear harness
S250 Rear harness
