Barometric Pressure Sensor: Description and Operation
Barometric Pressure (BP) Sensor:
The Barometric Pressure (BARO) sensor is a frequency generating device producing varying signals depending on barometric (atmospheric) pressure. The PCM monitors the frequency emitted from the sensor. The PCM calculates sensor input to optimize air/fuel ratio, idle speed, purge flow and A/C cutoff.
