Removal and Replacement
Powertrain Control Module:
CAUTION: Electronic modules are sensitive to static electrical charges. if exposed to these charges damage may result.
2. Remove the floor console and instrument panel insulator (046A24).
3. Disconnect the engine control sensor wiring connector from the Powertrain Control Module (PCM).
4. Remove the two PCM screws.
5. Remove the PCM from the vehicle.
2. Tighten the PCM screws to 3.7 Nm (32 in lb).
