Idle Speed/Throttle Actuator - Electronic: Service and Repair
1. Remove the air cleaner to intake manifold tube.
2. Remove the throttle body.
3. Remove the Idle Air Control Bypass Air (IAC BPA) valve retaining screws and remove the IAC BPA valve.
1. To install, reverse the removal procedure
2. Tighten the IAC BPA valve retaining screws to 2.5-3.5 Nm (22-31 in lb).
